Antenna replace/update options
Old Aug 8, 2021 | 10:07 PM
kkloberdanz's Avatar
Default Antenna replace/update options
I’m looking to replace the antenna on my 2001 XK8. I’d like o just update the power antenna with a 6”-8” black rubber antenna. Has anyone done this? Any things to look out for ar has anyone done this? I’m thinking I could look around and find a rubber grommet or something to get a clean tight fit and convert or update the antenna cable to work.
id appreciate any ideas or suggestions.
thanks.
Old Aug 9, 2021 | 06:15 AM
aeginc77's Avatar
I have been looking to do the same thing since I bought my 2004 XKR. I replaced the original antenna with one from ebay but what I have been looking for is exactly what you have described and I have yet to find one. Hopefully, someone will come up with suggestion.
Alan
Old Aug 16, 2021 | 05:49 AM
xk810024's Avatar
I'd like to do the same as my antenna motor doesn't work. Luckily in NYC I can still get all the FM stations fairly well in the down position. I have seen xk8 tutorials about putting an antenna inside the car in the rear...
https://www.jaguarforums.com/forum/x...004-xk8-60469/
and
Old Aug 27, 2021 | 08:39 AM
aeginc77's Avatar
I went ahead and tried your method. It works somewhat. I live in rural NJ and the antenna seems to work with stronger stations but the dipole seems to be very directional with the weaker stations. I can receive one of them fine in my driveway but then when the car is moving the station fades in and out. I was wondering if you had the same experience when you leave the NY area. I assume living in NY you can get all the NY stations really well.
Alan
aeginc77
Nov 23, 2023 05:30 PM
Daytona
E type ( XK-E )
25
Oct 29, 2020 10:45 AM
FastKat
Oct 13, 2013 03:54 PM
MBxjr01
May 16, 2010 07:57 PM
