Anybody who can help??
Old Apr 16, 2006 | 09:17 PM
Max's Avatar
Max
Default RE: Anybody who can help??
To avoid most, if not all, of the engine problems, Nikasil, tensioners, water pump vanes breaking, go for the latest XK your budget can handle. The engines of late model year 2001 have, from what I read, corrected those problems.
The Jags with new or rebuilt engines probably had the tensioners break causing the timing to jump, the pistons then collide with the valves and goodby engine.
Good hunting
Old Feb 5, 2013 | 09:06 AM
Richboy47's Avatar
The best years are 2002 - 2006. Reason better built engines little to almost no problems. I had a 1999 xk8 with 66,000 and never had problem with it wrecked it lol now I have a 2003 xkr SilverStone also never had a problem with it so I can't say. But from the changes they made to the engine from a 4.0 to 4.2 and getting rid of more then half the plastic in an on the motor they are a lot more durable?
Old Feb 5, 2013 | 01:22 PM
The OP was almost seven years ago in April 2006.
If he hasn't found one yet, he's probably gone for something else.
Old Feb 5, 2013 | 03:13 PM
gwagner's Avatar
Good advice nevertheless re. 2002-2006. However I think we've exchanged known, fixable mechanical problems on the earlier cars for inscrutable electronic complexities on the later models
