Automatic headlights do not turn on
Old Jul 10, 2014 | 10:38 AM
05XK8's Avatar
Default Automatic headlights do not turn on
Picked up a used 05 XK8 and found out on the drive home the Auto headlight feature does not seem to be working. I can manually switch them on. When in Auto mode and it gets dark I see a message indicating Lights are Off. In searching through threads I find that one possibly is the the light sensor on the mirror. Another possibly is the switch located on the steering column. Looking at some of the wiring diagrams posted there are a couple of modules that may not be working correctly and causing my problem.
Does anyone have information on how to identify which one(s) is not functioning?
Old Jul 10, 2014 | 11:46 AM
oldmots's Avatar
It is probably the switch, you should be able to test it if you take it out. If the switch is turned to auto and the instrument panel module does not know it, it will tell you that the light switch is off when the sensing unit indicates that the lights should be on. The switch is the first suspect.
Old Jul 10, 2014 | 12:23 PM
05XK8's Avatar
Thanks for the feedback. Two questions.
Do you know if when you turn the headlight switch to Auto there is any kind of indication that you are set to Auto on?
Do you know where I can find instuctions on how to take the switch out/apart?
Old Sep 1, 2014 | 10:36 PM
Chuck Schexnayder's Avatar
05XK8----
I have the same problem. Did you ever get your fixed?
Chuck
05XK8 Conv.
Old Sep 3, 2014 | 09:06 PM
05XK8's Avatar
Originally Posted by Chuck Schexnayder
05XK8----
Chuck
05XK8 Conv.
Actually I did. The problem was with the switch on the steering wheel column.
I was experiencing a couple of things related to the headlights and it could have been the mirror sensor, the headlight module or the switch. Since I purchased a warranty with the car I decided to let someone who knows Jags diagnose and then I would decide if I would attempt the fix or not. Since this was a covered repair I let the repair shop fix. This also gave me an idea on how big a deal it was going to be if I needed to use the warranty again. Good news was the repair shop called and let me know even they were surprised on how easy they were to deal with.
Old Sep 4, 2014 | 05:58 AM
When troubleshooting:
1. complete failure of the Auto Headlight function usually points to a mirror sensor fault.
2. warnings appearing in the Instrument Pack message centre about lights off means the mirror sensor is working but the steering column stalk switch is probably at fault.
99xk8guy
May 28, 2024 09:36 PM
avern1
Sep 8, 2015 06:25 PM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
