Battery not charging indication
Old Feb 10, 2013 | 10:08 PM
deelli's Avatar
Default Battery not charging indication
Need help with understanding the logic for the battery charge indication system on my 1997 XK8. Let me say upfront this is a conversion project, so the original system has been adapted into a GM system. I’ve used the original SW (gray/white stripe), charge indication wire (as suggested in conversion instructions) with a 1000 Ohm resistor connected (have also connected without resistor and left open with no change), to a switched 12v power source (used the pink/white stripe wire), but the red light in the charge meter and a battery not charging indication remain on. I have checked at the battery (with meter), and with the car running the voltage in ~14.4v.
My question is what are those indicators looking for to recognize charge?
Old Feb 10, 2013 | 10:16 PM
WhiteXKR's Avatar
Try connecting the grey/white wire going to the instrument cluster to ground. Make sure nothing else is connected to this wire.
Old Feb 11, 2013 | 09:58 PM
deelli's Avatar
Thanks for your response...tried grounding the gray/white wire today, no change in the indications.
Forcedair1
Sep 8, 2025 01:57 PM
Rivguy
Nov 13, 2022 02:55 AM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
jaguarbill
Sep 5, 2015 11:43 AM
