Can anybody help have a problem removing brake disc
Old Jun 23, 2016 | 07:36 AM
Jag1968's Avatar
Default Can anybody help have a problem removing brake disc
Hi fellow jag lovers I'm having trouble removing rear brake
Disc/drum after freeing up disc with hammer I'm able to slide disc in and out by hand but drum stops at cylindrical edge of hub center I've slackened adjuster and brake cable is there something I'm missing
Thanks for any help
Old Jun 23, 2016 | 07:43 AM
Jag1968's Avatar
Sorry it's 2004 xkr
Old Jun 23, 2016 | 08:38 PM
ccfulton's Avatar
If you've slackened the handbrake adjuster through the small hole in the rotor and it is simply stuck, you could try wire brushing the hub edge to clean any rust. Maybe even use some penetrating oil on the rotor / hub.
I also found that a 3/8 socket extension fits into the vents pretty well and makes a good handle to pull on.
Magnumforc
XF (X260)
Oct 23, 2016 03:14 PM
TreVoRTasmin
Apr 18, 2016 10:08 PM
EZDriver
Apr 12, 2016 06:30 PM
oyster
Apr 3, 2016 09:41 AM
Chase6495
Mar 29, 2016 09:07 AM
