Can excessive negative camber be due to worn shocks?
Old Feb 8, 2013 | 09:36 AM
Frog's Avatar
Default Can excessive negative camber be due to worn shocks?
I think the negative camber on my rear wheels is excessive. The previous owner of the car said the only real mechanical problem he had with the car was how fast it went through rear shocks.
How can I test for worn shocks (I have the $$$ adaptive ones) and could this explain the camber?
Old Feb 8, 2013 | 09:53 AM
RJ237's Avatar
If the camber is excessive when the car is stationary, it's not the shocks. They have no function then. If the springs are too short or the mounting pads have collapsed, that will increase negative camber. Have you checked the ride height? At least you can change the rear camber with shims.
If the ride height is correct, and the camber in spec., the shocks could be a problem if you lead- foot that SC engine.
Old Feb 8, 2013 | 10:15 AM
Paul Pavlik's Avatar
I would recommend replacing the factory Axle Shims (probably 4mm) to the thickest available, 7.5mm.
I did this when I installed Lowering Springs on my car.
Old Feb 8, 2013 | 10:19 AM
Frog's Avatar
Thanks for the advice, guys. Where does one procure 7.5mm shims and is installation a DIY job?
Old Feb 8, 2013 | 11:00 AM
Brutal's Avatar
Originally Posted by frog
thanks for the advice, guys. Where does one procure 7.5mm shims and is installation a diy job?
moderatly yes, but its a pia, and youll need to realign when done as changing camber changes toe. Also acceleration squats the rear suspension and will increase negative camber as a result on accel. But, if youre -1.5* or less you should not have a camber wear issue
Old Feb 8, 2013 | 04:17 PM
SteveJacks's Avatar
Agree, I have -1.2 and -1.5 camber on the rear and there is no uneven wear after 10k miles, I have a slight toe in to help correct and all is good. In fact, same in the front too with the toe in.
hoodun
May 25, 2020 09:08 AM
Harry Dredge
Oct 10, 2015 09:33 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Don R
Sep 14, 2015 12:34 PM
KarimPA
Sep 12, 2015 08:15 AM
