car is crazy
Old Jun 14, 2015 | 04:26 PM
Jag happy's Avatar
Default car is crazy
97 xk8. Red engine failure light. Yellow stability light. When this happens the idle is erratic. Turn it off. Sits a while. Lights out. Drive it. It does it again. Code reader seems to be getting no power as it won't even come on. Regardless no codes. Ideas?
Old Jun 14, 2015 | 04:46 PM
test point's Avatar
Early cars suffered many throttle body issues including a service recall that replaced all that owners knew about it. That has expired.
There is a place up in the Johnson City, TN area that rebuilds them but the name escapes me at the moment. Someone will supply that shortly I am sure.
Check the fuse for the Data Port. Fuse chart in the Sticky above if you don't have one.
Old Jun 14, 2015 | 06:34 PM
RJ237's Avatar
It's ASI Tom.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
Old Jun 14, 2015 | 06:43 PM
brgjag's Avatar
1997, all those issues, I would bet it is the main computer. Mine did the same stuff, TB replaced 2x. I had the computer sent out 97's ecms are known to be problems, got it back, put my orig TB back on it, all was fine. I used ASI also.
Old Jun 14, 2015 | 07:24 PM
aode06's Avatar
If you are getting no power to a code reader, that's a problem in itself.
Someone will chime you in on the location of the ecm and that fuse to check.
Old Jun 15, 2015 | 11:30 AM
Deltasierra's Avatar
Before you get involved in expensive fixes make sure the battery and alternator are good. Low system voltage will cause a whole load of issues, regarding the code reader, mine does not take any voltage from the car it just reads the data from the ECU.
Old Jun 15, 2015 | 01:49 PM
Jag happy's Avatar
So where is the computer located? Do I just unplug it and send it off?
Old Jun 15, 2015 | 02:01 PM
WhiteXKR's Avatar
On the passenger side, under the hood on US vehicles, under the black plastic cover near the windshield and front quarter panel.
ALWAYS disconnect the battery before plugging or unplugging any electronic module.
Old Jun 15, 2015 | 02:28 PM
RJ237's Avatar
If you are sending it to ASI, call or email first and get a work order#.
Old Jun 15, 2015 | 05:21 PM
Jag happy's Avatar
Thanks guys. I think I will try sending the ecu for repairs first and hope for the best.
Old Jul 1, 2015 | 04:01 PM
Jag happy's Avatar
Thanks to you guys and your vast knowledge I had the ecm rebuilt and it appears to have cured the problem. Thanks!!!
Old Jul 3, 2015 | 08:09 PM
Stamford's Avatar
Great feeling, isn't it?
I couldn't own my car without this group.
Old Aug 17, 2015 | 06:42 PM
willtoliv's Avatar
I worked in the car stereo business for over 35 years, so I do know a little bit about electronics. That said, my neighbor in the shop next door had an auto electric shop. They repaired starters, alts and all the other electronics. They did this for many years. While having a beer or two with him one evening I asked how they repaired ECM/ECU's. He told me that 95% of the time they just left them on the shelf for a week and all the problems would go away. Basically just letting all the internal capacitors bleed down to zero voltage. The quick and dirty way was to, with the unit on the bench out of the car, to short all the terminals on the plug to ground (unit chassis). If you have to send the unit out for repair anyway you might want to give this a try first. The other 5% of the time they ordered rebuilt units just like we do.
Newsguy
Aug 30, 2015 11:27 AM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Marque
Aug 27, 2015 11:53 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
