Car runs once again
Have been doing quite a bit of work lately. Removed valve covers and found I had new type tensioners. While inside I determined one Vvt was broken. Yes, broken in half. Ordered new vvts gaskets and all seals. Also found a coolant leak I thought was valley hoses but when removed they looked new along with other hoses. Finally decided leak was from around water pump area so ordered everything new. Water pump, tower, thermostat, all hoses, seals, and gaskets. Put together and no codes or leaks can be found.
