Caster shims
Old Sep 27, 2025 | 04:20 PM
larrylinda02's Avatar
Default Caster shims
Where can I get 98 Jaguar xk8 caster shims?
Old Sep 27, 2025 | 07:18 PM
motorcarman's Avatar
Just get 1/16" and 1/8' standard alignment shims and open/cut the 'mouth' to increase the diameter of the 'U' shape to fit the larger castor bolt.(the standard shims will not fit over the bolt)
I threw the washer type shims away when I noticed the original ones were mismatched/missing from the bolt.
The factory setup is specific to RHD or LHD so I just inserted the correct sizes for my LHD when I had it apart.
This U shape is easier to adjust than the washer type if you need 'tweaking'. (loosen, swap, replace)
Old Sep 27, 2025 | 07:47 PM
Dr. D's Avatar
Good advice from Bob, and additionally, I would also add some similar 1/32" shims to the arsenal.
Old Sep 29, 2025 | 12:55 PM
NorXKR's Avatar
Original there should be 4 shims in total, each side of the car. Two of them are 0,9mm thick and two that are 1,6 mm thick. Nothing more, nothing less. Adjust caster by moving shims, not remove or add anything.
Old Sep 29, 2025 | 01:29 PM
I think I used 1/32 and 1/16 shims as that is close to the metric shims OEM.
1/32 is close to .9 and 1/16 is close to 1.6.
Been a while since I had the suspension apart but it was missing shims and they were in the wrong places.
I put the 1/32 and 1/16 shims in the order for LHD cars.
You can swap them around to increase or decrease castor if something is bent or out of spec to get it closer to correct.
larrylinda02
Sep 30, 2025 10:16 AM
alanroberts50
US Western
Apr 20, 2021 10:35 AM
66RBS
Aug 5, 2019 08:23 AM
dneu
Aug 6, 2012 09:49 PM
whm54
Jan 4, 2012 06:23 PM
