Center console vent has unknown function?
Old Dec 19, 2020 | 10:22 AM
jagophile's Avatar
Default Center console vent has unknown function?
What is the function of the vented dish between the radio and shifter in the center console? I'm looking for a place to put a USB outlet and this is a candidate. Are there sensors or electricals under it? The vents imply some sort of cabin temp function but I can't find anything about it in the manual. I'm referring to item 21 in the Jag manual that is not a switch, it is some kind of stepped and vented container.
What is arrow 21 pointing to?
Vented and stepped, what does this achieve?
Old Dec 19, 2020 | 10:27 AM
Barry_Tucker's Avatar
It's a coin holder I thought
Old Dec 19, 2020 | 10:44 AM
brobin's Avatar
You could put it there but probably better looking to put in the console. I just put a low profile charger in the lighter socket.
Old Dec 19, 2020 | 12:07 PM
ccfulton's Avatar
In a convertible there is a switch located there for the top. In a coupe it is just a coin holder with nothing of significance underneath.
Old Dec 19, 2020 | 01:39 PM
I know I've seen the Coin Tray mentioned in one of the Driver's Handbooks but can't find it. Here's the relevant extract from the Parts Catalogue:
Nothing directly beneath it to worry about other than harness runs but clearance could be restricted:
Old Dec 19, 2020 | 06:11 PM
jagophile's Avatar
Thanks for this everyone. I'm looking at the console so I can see the voltage display on the USB outlet. But if clearance is an issue it might end up inside the console. Here is a pic of the plug:
Abacab
Apr 7, 2018 07:48 PM
spindoc
Jul 4, 2017 01:21 PM
vdpnyc
Oct 30, 2016 12:13 PM
Warspite
Aug 7, 2015 10:57 PM
xjrjag
Jul 9, 2015 01:41 PM
