Center dashvents
Old Jul 2, 2013 | 10:10 AM
randyb's Avatar
Default Center dashvents
Left side blows ice cold and the right side blows luke warm.
What could cause this?
Old Jul 2, 2013 | 05:49 PM
stevepaa's Avatar
I think there is a single feed from behind. strange.
Old Jul 4, 2013 | 10:21 AM
Jag13cat's Avatar
Default Center Dash Vents
randyb;
From what you are describing, you may have a blend door in the evaporator that is not fully opening, or a split hose leading to the dash vent that is pulling ambient air into it and then out to the dash vent.
You may try running the Heater and A/C through their varies cycles, at different settings, to see if heat is coming through the vents with the same or different volumes. This may open and close the blend doors properly.
Additionally, look uner the dash behind the vents, making sure the hoses leading to the vents are not split.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
adam699
Oct 13, 2015 05:53 PM
Stilling
Oct 5, 2015 04:23 PM
42Ajd
Sep 26, 2015 07:04 PM
