That was close
Old Jun 10, 2014 | 12:23 PM
steeevo's Avatar
Default That Was Close
Attached Thumbnails That was close-ccbbf9f0-7433-44bd-a8ad-5c7ff01e90e7_zpsm6pdd0px.jpg
Old Jun 10, 2014 | 12:46 PM
No water and no petrol?
I hope you took the pic at the pump.
Old Jun 10, 2014 | 12:53 PM
p-Rock's Avatar
when your using the FUEL USED meter after RANGE dropped to 0 to see if you can make it, thats when you know you have an issue with keeping gas (in the car).
Old Jun 10, 2014 | 09:43 PM
tberg's Avatar
The range readings are certainly not accurate as they rely on the computer analysis of how you were recently driving. Although I don't make a regular habit of it, I have many, many times gotten to the 0 Range reading but not run out of gas (yet). My guess is that there is 20-30 miles left on the tank from when it first gets to 0.
Old Jun 11, 2014 | 03:38 AM
steeevo's Avatar
Well the tank states 70l from full to empty on the gauges but there is 5l un accounted for so when it reads 0 range you still got 5l remaining.
I downloaded the manual
Old Jun 11, 2014 | 12:23 PM
Johnken's Avatar
I think Seeevo is on the right track here. The miles remaining seem to be tied to the Fuel guage reading, which as admitted by Jaguar leaves about 2 gallons in the tank at the empty reading. John
Old Jun 11, 2014 | 03:09 PM
WGS's Avatar
WGS
Default One gallon left!
My first car was a 1958 VW "bug". There was no gas gauge at all. When you felt the engine sputtering, you reached down under the dashboard and turned a valve. Then, you knew you had about enough gas for 35 miles. The valve did nothing more than allow the gas to flow from a lower point in the gas tank.
philwarner
28
Jul 11, 2017 10:21 AM
hkmcmast
Nov 29, 2015 06:56 AM
millertic
Sep 30, 2015 08:11 PM
