code P1121 2001 jag XKR tried everything
P1121 throttle position sensor not consistent with mass air flow sensor. I cleaned all connections and mass air flow. Set throttle at 100%. After being driven for 20 to 30 minutes car will go to fail safe (the warmer outside plus 25 c the more it happens), turn it off for a minute,restart and all is well. Now it is happening more frequent. My garage says it is the throttle position sensor, they came across a similar situation. does any one know where I can buy this sensor with out buying the whole throttle body. The sensor part # is LNE1662AB. Has this happened to you and any thoughts
