Convertible top: conversion to manual latch operation
Old Feb 2, 2013 | 12:01 PM
  #41
Dennis07's Avatar
Originally Posted by steveinfrance
I can try.
On a normal hydraulic system you've got a series of spool valves which have three positions 1-R-2
At rest (in 'neutral') all the valves are in the 'R' position so the pump output goes straight back into the reservoir, i.e; the pump does no work.
As soon as any valve is moved to (e,g,) '1' the return flow is cut off and the pump output is diverted to side '1' of the ram. At the same time side '2' of that ram is connected to the reservoir so fluid pushed out of side '2' by the piston goes back into the reservoir.
To do this with solenoid valves requires either a three port valve with some fancy plumbing or two 2 port valves per cylinder.
Thanks. I confess to knowing nothing about how the valving is done. I guess I'd summarize my reasons for believing it has to be "valve always open, switched directions" rather than "valve open/closed" this way:
- I can't see another way to interpret the documentation, pg. 2
- if Off means closed, then there can't be times where latch or main valve is Off, but the latch or main rams are being moved. That seems to conflict with the opening and closing sequences, pgs. 5 and 6. (There is no conflict if Off means "permit flow to compress rams".)
- The reservoir has to be switched from one side to the other. I can't see any way that gets done if the valves are just doing Open/Closed.
I guess at this point it's just academic. Still fun though.
edit: Come to think, for me it is not academic. To do the conversion to manual latch (remember that?) I need to replace the latch hose circuit with some sort of dummy. What can work there depends on what the real meanings of "On" and "Off" are for these valves.
Old Feb 3, 2013 | 05:23 AM
  #42
steveinfrance's Avatar
Yes, I'm afraid that's what I've been binding on about.
If pressure is applied to latch and lift simultaneously (which your earlier post convinces me is true) then you must cap off the latch outputs.
If the pressure is magically switched between lift and latch then you need to jumper them to avoid overloading the pump.
In my case that wouldn't matter since the relief valve would blow off excess pressure but you might stall the pump.
(debates about valve vs resistor carry the death penalty here BTW).
Old Feb 3, 2013 | 07:48 AM
  #43
Dennis07's Avatar
Thanks. I would be worried about my conclusions if you saw this otherwise. I think I see a middle ground:
These have problems ...
- Capping the latch ports: guarantees we don't bleed off the pressure needed to raise/lower the top, but we risk dead heads when the pump thinks its operating the latch. (This option is OK with relief valve in place.)
- A wide-open shunt between the latch ports: no dead heads but prevents the pump from making enough pressure to raise/lower the top.
So ...
How about a dummy hose circuit between the latch ports with some sort of orifice/restrictor in it. Allow some tiny amount of flow so we don't ever get a dead head, but not so much as to knock down the pressure needed to raise/lower the top. We started to touch on this idea a few posts back, circa post #23. (I don't know how to size the orifice; any help much appreciated.)
I plan to use capping for initial testing and, yes, I'll have to be careful. There's a re*i*s**r on my pump, whick makes this less scary (to me anyway). But no matter what, it's gonna need to get more then a little warmer here before we run this to ground.
Old Feb 3, 2013 | 08:00 AM
  #44
Because the caps are so cheap I'd just bung them on as you say.
I'd guess you'll know in a few seconds if it's a Bad Idea because you'll hear the pump labour and your Rotsiser will get hot.
Old Feb 3, 2013 | 08:14 AM
  #45
What are your thoughts on Lanny's arrangement where his latch ports are open and apparently nothing comes out?
Old Feb 3, 2013 | 08:32 AM
  #46
Good job someone can read.
I must be wrong then, the solenoid really does turn the flow on and off.
That would be the sensible thing to do - disconnect the supply to the latch solenoid, crack open the pipe unions and see if anything comes out.
Old Feb 3, 2013 | 08:35 AM
  #47
Dennis07's Avatar
Lanny's ports are capped, not open. If they were open we would have a biblical scale green shower.
Old Feb 3, 2013 | 08:44 AM
  #48
Dennis - does he say that ? Is it somewhere in the other v. long thread ?
Old Feb 3, 2013 | 08:54 AM
  #49
Dennis07's Avatar
Steve,
Yeah, I'm sure I recall it being mentioned, but couldn't say exactly what post.
Maybe Lanny will chime in and confirm. (This carries a certain risk for me; if the ports are open, my head will explode.)
Old Feb 3, 2013 | 08:57 AM
  #50
Agree re head explosion - I can't make it work.
I'll pm Lanny - meanwhile apply a tight, wet elasticated bandage to the forehead.
Old Feb 3, 2013 | 10:20 AM
  #51
Originally Posted by Lanny
They work very well. The hoses to the latch are disconnected at the pump, the outlets stand open. It looks like they disabled the soleniod valve that would normally send the fluid to the latch. I am sure they did this because I found evidence of the "green shower" in the header.
Here it is, from post #8 I'm pretty sure that he says the same thing in his other thread.
Old Feb 3, 2013 | 11:05 AM
  #52
Dennis07's Avatar
I can't find what I thought I remembered reading.
If both latch ports on Lanny's pump are in fact wide open (it seems possible for one to be open, the one opposed by the setting of the disconnected? latch solenoid) and it does not expell fluid when the pump runs in either direction, then I'm hopelessly confused.
I hope Lanny will see this and tell us, doing a close look to see the condition of both of the pump's latch ports.
Old Feb 3, 2013 | 11:18 AM
  #53
He's toddled off to look closely at the pump so expect a reply soon.
Old Feb 3, 2013 | 12:19 PM
  #54
xenophobe's Avatar
Originally Posted by Jon89
xenophobe,
Your braided hoses may never fail, but there are still a number of weak links in this Rube Goldberg-like chain. Pumps, fittings, microswitches, and everything in between all add up to multiple points of potentially expensive failures. I still believe that a simple manual top with interior handle-type latches on the driver side and the passenger side would be the ideal solution....
I understand all that. Of the whole system, there is one hose that is more likely to fail than any of the other components, and I believe that it was the factory installation process that was primarily responsible. The two failed hoses that I have seen appear to have had torsion twists at the same break point... the plastic coating gets brittle and the torsion helps to crack and separate the hose until it fails. I replaced those.
I know the lift ram seals and top latch are also prone to failure, but they're far less likely to fail. If that happens, I'll deal with it when it does.
Good luck, but to me this is not a viable option.
The only reason I would consider this is for weight savings.
Old Feb 3, 2013 | 04:19 PM
  #55
Lanny's Avatar
Hi Guys,
boy I sure don't want to be responsible for anyone,s head exploding. I rechecked my pump, and there are definitely not caps on the outlets. Is it possible that it is blocked internally somehow.However, I don't see anything to support this. [IMG]i:dsc06971.jpg[/IMG] I hope this picture gets through. ( I am not sure how to include a picture for sure)
It is my opinion that one of the two solenoids is what decides when, and if ,the fluid goes to the latch. I believe that solenoid is disabled on my car. As I have said before, the top goes up and down just fine. My rear windows are controlled by a separate DPDT switch. The only problem is the "top not latched" message that won't go away, even if the top is retracted.
If this picture does not come through maybe someone can explain how to do it right. I have several pic's I can post. Stay strong my friends.......
Old Feb 3, 2013 | 05:35 PM
  #56
Gus's Avatar
Gus
Déjà vu!
Old Feb 3, 2013 | 08:45 PM
  #57
Spurlee's Avatar
Originally Posted by xenophobe
The ultimate answer to me was buying the Coliflower braided hose kit to replace the latch hoses. I have no fear of using my top and I have no fear of that hose ever failing.
I agree with that! Prior to replacing my hoses with the Coliflower S/S lines I insalled the pressure reduction valve. After replacing the lines I had the top latch rebuilt with new, heavy duty seals. Then I went ahead and installed the Remote Top from WhiteXKR.
The price for all this bulletproofing was about $1,000 but now I use the top without fear whenever I want; the top goes up and down more often than a spring break girl's on Bourbon street...
Old Feb 3, 2013 | 08:53 PM
  #58
Spurlee's Avatar
I looked brefly at purchasing a 2000's era Mercedes SL500. If you want to see a REALLY complex system check out the hard top convertable set up they have...
Their forum is filled with unhappy owners and expensive repairs...
Old Feb 4, 2013 | 08:15 AM
  #59
Lanny's Avatar
Default Try again to post picture of my pump
[IMG]jag pump.jpg[/IMG] All right! that is a little more helpful I think.
[IMG]jag pump2.jpg[/IMG]
Attached Thumbnails Convertible top: conversion to manual latch operation-jag-pump.jpg   Convertible top: conversion to manual latch operation-jag-pump2.jpg
Old Feb 4, 2013 | 08:29 AM
  #60
Dennis07's Avatar
Yup, we see them. Those ports sure look plugged to me which, if so, defers my head explosion. (After last night, it might be better if it did. Ouch!)
I did a quick test on my car and found that if I loosen the latch hoses at the pump, even with latch valve off, fluid gets pushed out. This is the only behavior, IMO, that makes sense given what the 501-11 doc tells us about the valves.
Not for Lanny, but a super-bowl inspired thought for the day: before beginning an end-zone dance, be sure which end-zone the ball is in.
