Convertible top rubber seal replacement?
Old May 16, 2012 | 10:50 PM
xenophobe's Avatar
If you ever get a tear or rip in the foam rubber seals, go to a RC or hobby store and pick up some cheap CA glue... I haven't needed to do this, but it's the proper glue and in most cases if you're careful, it shouldn't even be noticeable.
Old May 18, 2012 | 07:43 PM
oldjaglover's Avatar
Originally Posted by hypoluxo
Thanks for the help. Let me know how you would like to handle payment.
I made the order, but I had added to it 2 ort 3 times so wait until I get the box to be sure what came.
Old May 18, 2012 | 11:16 PM
hypoluxo's Avatar
Cool, thanks. Bump this thread to the top or send a pm when it comes in.
Old May 19, 2012 | 11:23 AM
2002XK8Orlando's Avatar
let meknow
Old May 24, 2012 | 10:09 PM
Davebc's Avatar
I'll be doing this with my weather strip very soon!
What I also need is the rubber seal between the drivers door glass and rear glass. Does anyone know if I could get that anywhere please?
Old May 25, 2012 | 03:10 AM
Hopefully, the box(es) will be here in a few days....or after the holiday weekend.
Old Jun 2, 2012 | 06:23 AM
I got the box of seals and some other things. I think there's a left and right of both the center section and the front section with the little "foot" on them. I haven't test fitted them or held them to the car so I'm not exactly sure which side is which yet. I am pretty sure I only need the driver center section. I remember at least 2 people needed one or two of these seals. After I confirm their fit and make sure they are all perfect, I'll give you a price...realllly waaaay below the "list".
http://www.gaudinjaguarparts.com/par...iagram=4730390
Old Jun 2, 2012 | 06:30 AM
  #28
Do you still need these? Both sides? What about the rear section over the rear side windows?
Old Jun 2, 2012 | 09:34 PM
H20boy's Avatar
Hey oldjag, I am in need of a passenger side, #3 (center section) can you spare a square?
Old Jun 2, 2012 | 09:50 PM
  #30
hypoluxo's Avatar
I need the rubber piece that attaches to the convertible top that fits over the passenger front window.
Old Jun 3, 2012 | 06:32 AM
  #31
OK...I have Hypoluxo, Orlando, and H20BOY all #3 right side middle section??
I thought one or two of you needed the front section (like #2).
Old Jun 3, 2012 | 06:25 PM
  #32
hypoluxo's Avatar
I hope I have successfully attached an image. If so, that is the piece of weatherstripping I need. It is the front-most piece on the convertible top over the passenger front window.
Old Jun 3, 2012 | 09:56 PM
  #33
Davebc's Avatar
1997 JAGUAR XK8 Parts - Direct JPLV Porsche Parts.com
I found the missing piece in my trunk under the spare today! Thanks for thinking of me.
David
Old Jun 3, 2012 | 11:30 PM
  #34
H20boy's Avatar
oldjag, I just re-checked the correct part on the car, its the 'front' right (passenger) #2 , same as hypo it appears. Sorry for the confusion, and thanks for the confirmation request.
Old Jun 3, 2012 | 11:54 PM
  #35
OK. I received the right and left side third pieces...which are the shorter ones right behind the ones you both are identifying. And, I got both sides of the ones with the little angle "foot". By the pics in the diagram they look like the correct ones for both of you. If you can verify the exact shape I think we can get you both set up. I'm pretty sure there is a part number on each piece, but you'd have to remove them first.
I just looked at them again. They are definitely the pieces you need, but one is for the right and one is for the left.
There's only 3 pieces so we should be able to be smater than the rubber or the top.
Old Jun 4, 2012 | 12:17 AM
  #36
Originally Posted by 2002XK8Orlando
Add me to that list Driver's and passengers need to be replaced
OK....the right front piece (passenger, #2) is already spoken for, but I have the left side front and the right side middle (short, #3) pieces left.
Old Jun 4, 2012 | 09:12 AM
  #37
Glenn Barickman's Avatar
Wow, Just stared reading this thread. I will take the right side #3 if it is still there. I also need a right #2, but I see that is gone. Can I order another one? You can PM me with payment info. Thanks
Old Jun 4, 2012 | 09:47 AM
  #38
H20boy's Avatar
Well, I almost got in on the good deal, but thanks nonetheless. You'll find buyers for those other pieces, the front and center pieces seem to be the first to get damaged over time.
Old Jun 4, 2012 | 11:16 AM
  #39
I'll see if I can get another piece or two, but it's hard at that price.
Old Jun 4, 2012 | 11:21 AM
  #40
Do you still need the driver side front piece (like #2 in the diagram)? I need to know because others are interested.
