Coolant
Old Jun 28, 2017 | 12:28 PM
RLeembruggen45's Avatar
Default Coolant
HI Folks! Have 2006 XK8 convertible. Would Dexcool be suitable coolant for my car? If not, any suggestions?
Old Jun 28, 2017 | 01:38 PM
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Jun 28, 2017 | 01:46 PM
dsd's Avatar
dsd
Orange dexcool should be ok. If adding it to existing fluid make sure it's the same kind and ensuresolution density.
Old Jun 28, 2017 | 02:19 PM
Jon89's Avatar
I have used Dexcool in both of our Jaguars from day one of ownership. No issues (and it meets the required specs)....
Old Jun 29, 2017 | 11:30 PM
Julian Black's Avatar
Hi, in research Ive found Dexcool, not recommended for Jags or Fords. Just GM cars. Not sure why, something about some additive isn't great.
Anyways I use the Pentosin/ Pentofrost red cap version (pink stuff).
Haven't hear nothing bad on it.
Old Jun 30, 2017 | 10:22 AM
fmertz's Avatar
Get the data: Vehicle Spec Book PDF
Page 103 lists this spec: WSS M97B44–D
Advance lists this for DEX-COOL:
Prestone DEX-COOL meets or exceeds ASTM D3306 and SAE standards for corrosion protection and meets GMW3420 (GM 6277M), Ford WSS-M97B44-D and property and performance specification requirements of Chrysler MS12106 (MS-7170 & MS-9769)
The short version is that the 4.2 engine is designed for this WSS spec, and DEX-COOL meets it.
As pointed out above, double check what is already there. If anything other than orange (dip a paper towel in it to be sure, the fluid in the tank has a weird sheen that looks sort of greenish to me), don't add anything for now.
Best of luck, keep us posted.
