Coolant Level Light On But Not Low
Old Oct 2, 2010 | 01:13 PM
Alwann's Avatar
Default Coolant Level Light On But Not Low
2001 XK8, 59K miles. Low coolant light came on the other day. Reservoir was down a little. That made sense because I had been doing a lot of highway driving on hot days. I topped it off. After about 100 more miles and two days later, it's on again, but tank is full. Gaskets were replaced recently. Thermostat is about a year old. Engine temp is normal. I don't believe this is a leak.
Could it be a switch? Bad cap on the tank? Other possible causes or symptoms to look for, anybody.
Old Oct 2, 2010 | 02:14 PM
H20boy's Avatar
Its more than likely the sensor in the expansion tank. Some people have removed the tank and tried to repair the sensor. There are a thread or two with some pictures related to that.
Or, you could just buy a new tank online for $170 roundabouts, and fix it that way. comes with the sensor installed and a new cap.
Old Oct 2, 2010 | 07:55 PM
Brian2000XKR's Avatar
"Or, you could just buy a new tank online for $170 roundabouts, and fix it that way. comes with the sensor installed and a new cap."
Good advice, that's exactly what I had to do earlier this year.
Good luck,
Brian
Old Oct 3, 2010 | 12:13 AM
XKR Brian's Avatar
check the sensor at the bottom of the expansion tank, they can come loose and fall down about 2 inches and cause this. I have had sucess super gluing them back on, 2 minute job
Wolfy
May 28, 2024 08:06 AM
afterburner1
Dec 16, 2015 12:12 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
