cooler thermostat
Old Oct 9, 2011 | 05:13 AM
hdsg's Avatar
Hi all:
As usual you have all been a great help.
I will keep monitoring but it sounds like my temp is within spec.
And now I know what the stock thermostat is.
I will be replacing upper / lower and short rad hoses as well as flush and coolant ( orange I believe in my case )
So was going to order a cooler thermostat but I believe will order the stock one
Water pump and thermostat housing was changed recently before I bought the car so I don’t have to worry about those
Thanks again for your input
Howard
Old Oct 9, 2011 | 06:29 AM
Gus's Avatar
Gus
Thought this link might help Jaguar thermostat housing 4.0 xk8
Old Oct 10, 2011 | 04:40 AM
Brutal's Avatar
last time I checked we still are talking about lower coolant temps
Old Oct 10, 2011 | 06:54 AM
Gus's Avatar
Gus
Brutal you are correct. I just added the link to help him with his hose replacement.
Old Oct 10, 2011 | 02:28 PM
hdsg's Avatar
Gus:
Thanks for the link
Great help
Yeah that lower hose looked like I needed really really small hands to get in there
Actually kinda figured the fan housing had to come off
Was going to check my JTIS but thanks to you I can bypass that
Looks fairly straight forward ( although I know from experience this is not often the case )
Tks again
Howard
Old Oct 6, 2020 | 08:14 PM
Ktmscott's Avatar
My thought is to run without a thermostat due to the high temps here in Texas most of the year 100 to 110 in summer. Sometimes mid 80’s during Christmas. Any thoughts?
Old Oct 7, 2020 | 11:38 AM
stu46h's Avatar
Colder air is more dense, warmer air is less dense. In colder temperatures you're actually getting more air drawn into the engine which results in more power even it it's too little to notice. That's why an intercooler is used on a turbocharged or supercharged engine, to release the heat generated from the compression of the air.
The engine is designed to run at a certain temperature, and as mentioned in previous posts, there is not need to try to redesign what the engineers at Jaguar have already done. In fact, it's probably a bad idea as you have a good chance of screwing something up out of ignorance unless you're an engineer with enough knowledge and experience to improve on the work of the engineers at Jaguar or Ford.
Old Oct 7, 2020 | 04:26 PM
  #28
michaelh's Avatar
Doing so may not give the result you expect. See this thread of Stamford's:
https://www.jaguarforums.com/forum/x...0/#post2246017
Old Oct 7, 2020 | 11:06 PM
zray's Avatar
don’t do it. The factory thermostat will get your car up to the proper operating temp faster than the lower temp thermostats. That should be your primary concern. If you put in a 180 F thermostat your car will not reach the proper operating temp on short trips. Put many of those back to back and your oil will turn to sludge from all the moisture that didn’t get burned off by a higher temp.
any thermostat, of any rating, will not impact the highest temp an engine will run at, a thermostat only sets the low temperature. The high temp of any engine is determined by the radiator size and the air flow and coolant flow thru the radiator.
Z
dfwx
Mar 11, 2020 09:08 PM
Stamford
Nov 12, 2014 07:38 AM
Rey
Apr 20, 2013 02:08 PM
love's_jag
Mar 4, 2012 03:25 PM
