cooling system
Old Feb 18, 2021 | 03:50 PM
tcap1047a's Avatar
Default cooling system
In 2018, I decided to replace the plastic thermostat housing on my 2000 XK8 ( 95,000 miles ). The housing was badly degraded from 20 years of chemical attack, innumerable temperature transients, and erosion from flowing liquid. This year, I wanted to flush the cooling system completely. I removed the hose that comes from the top of the radiator to the water distribution pipe and found the plastic pipe to be on its very last legs probably for the same reasons the T/Stat housing had degraded. It was a loss of coolant event waiting to happen.
The moral of the narrative is, if you are going to replace your T/Stat housing, replace the water distribution pipe at the same time and save yourself some headaches., time, and coolant.
TomBroder
May 26, 2020 05:49 AM
apexjag
Dec 19, 2019 03:47 PM
Scruggs
May 16, 2016 12:36 PM
Catmobile
Aug 2, 2015 07:03 PM
01vandenplas
Dec 5, 2012 03:30 PM
