Coupe center console fixed!
Old Nov 24, 2018 | 08:49 AM
Timeisrelative's Avatar
Default Coupe overhead console bracket fixed!
I figured I would share! My 1997 xk8 coupes overhead console bracket was broken and epoxied and basically falling apart from age, causing my console to fall from time to time until I used trim tape to hold it up. I looked online, but as we know the coupe bracket has been discontinued (drrrrrrr). The one site, however, listed the convertible bracket for convertible/coupe. I thought “ok its only $10.50 Ill try. Needless to say it got here yesterday and the holes dont line up. I measured and there is basically an inch difference. I thought Id try to figure something out. I looked around and found an old metal angle bracket with holes in it. I cut off the ends about 2 1/2” in with my dremel and added two holes an inch off the center of the two predrilled holes. I found two machine screws and nuts and bolted the convertible bracket to the metal with the bolt heads on top and the metal underneath. I noticed that the one connector had to be moved, but left the plastic mount in its spot. I bolted it in, and was able to get it tight. I pushed the console up an “click click”. It looks like new! Held in very nice an tight! Figured Id share in case anyone else is have the same issue
Last edited by Timeisrelative; Nov 25, 2018 at 01:05 AM. Reason: Meant to say overhead, not center
Old Nov 25, 2018 | 09:52 AM
Johnken's Avatar
Nice job!
John
Stuart S
Mar 2, 2017 11:22 PM
Blake Bias
Oct 27, 2016 03:52 PM
Kaibigan
Jun 11, 2011 09:39 AM
1avguy
Apr 29, 2011 08:25 AM
greased_pig
XJ40 ( XJ81 )
Jun 22, 2007 01:10 PM
