Coyote transplant into XKR
Old Dec 14, 2016 | 09:13 AM
kulddy's Avatar
Smile Coyote transplant into XKR
Has anyone transplanted a Coyote (5.0-5.8) into a 2000 XKR withs a 6 speed Tremec?
Old Dec 14, 2016 | 11:59 AM
Ungn's Avatar
It would be a neat swap, but I would think it would need a hood scoop to fit under the bonnet in front.
I could take a tape measure to my 5.0, but the motor is tall in front, where the jag motor is not, with the rear throttle body. An LS1 is much more compact in comparison.
Old Dec 14, 2016 | 12:11 PM
SteveM's Avatar
This has measurements and info you may find useful:
https://performanceparts.ford.com/do..._july_2013.pdf
Old Dec 14, 2016 | 06:57 PM
kulddy's Avatar
Well I'm intending on putting in the TVS 2.6 blown model. It has a Jag hump in the middle and the XKR vents. So I'm thinking; DRY sump, lower mounts, raising the center bump. Improving the vents. Smaller dual disc clutch. I think it might fit!
Old Dec 14, 2016 | 08:07 PM
ccfulton's Avatar
Too wide, won't fit between the shock towers.
Major surgery to do that conversion.
Old Dec 14, 2016 | 08:48 PM
kulddy's Avatar
Kool, gotta do the rear anyway. Gonna cage it anyway.
Old Dec 14, 2016 | 09:02 PM
kulddy's Avatar
Plus I need better geometry F & R. Much bigger brakes and a whole lot of tire. Gonna go Vette chassin'. Move the motor back. Transaxle rear end.
Old Dec 14, 2016 | 09:03 PM
kulddy's Avatar
Could put a V6 eco-boost in the backseat!
