Crossover pipe
Old Nov 22, 2011 | 01:47 PM
walkman1's Avatar
Default Crossover pipe
I just received a new plastic crossover pipe for the coolant hoses on the front of the engine. It has the rubber o-ring type of gaskets built in. Do I need to add anything else to the area around the gasket when I do the install? I don't want any more leaks and I know my mechanic had to adjust the fitting of the o-ring gasket on the thermostat housing when it was replaced.
Old Nov 22, 2011 | 02:42 PM
Brutal's Avatar
NO
Old Nov 23, 2011 | 04:25 AM
pomosv's Avatar
I assume you mean whether you should add any sealant? Like Brutal said, no. I don't think there should ever be a need to apply sealant in the coolant system connections.
Old Nov 23, 2011 | 04:11 PM
walkman1's Avatar
Replaced the crossover pipe today. Some of the inside plastic near the o-ring had eroded, causing a void. I assume the chemicals in the coolant caused the issue.
GGabriel
Nov 22, 2018 03:53 AM
xjrjag
Oct 12, 2015 03:16 PM
NathanDD6
Oct 6, 2015 11:20 AM
baskervillema
Oct 1, 2015 06:43 PM
