Cruise Control kaput
Old Jun 6, 2014 | 01:27 AM
ChuckB's Avatar
Default Cruise Control kaput
Cruise control does not engage. Does anyone know where to start looking to fix this? I suppose it could be something as simple as a fuse, but where? If the fuse is fine, then step two? I'm sure this is not an unknown event in the life of the XK8. Thank you
Old Jun 6, 2014 | 02:52 AM
test point's Avatar
Do you have a check engine light? If so, have the codes read and post the actual numbers back here.
Your '99 XK8 cruise control is managed by the ECM and there are any number of OBDII codes that the first thing on the chart says that the CC is disabled.
I had an issue with the CC button on the center console that was causing an error message. A large number of operations of the switch seemed to clear it.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
leep123
Sep 30, 2015 03:41 PM
Camnelson324
Sep 27, 2015 08:48 AM
zdrapec
Sep 25, 2015 05:49 AM
