Daylight running lights how-to?
Old Aug 13, 2024 | 07:33 PM
Theo14's Avatar
Default Daylight running lights how-to?
Hi All,
My 2006 US model XK8, that has been registered in Canada since 2015 in 3 different provinces, now didn't pass the out of province inspection as it is possible to turn the DRL's off. On "auto" they work, but on "off" they don't. Garage quoted me "around 4 hrs" @ 150/h to put in a $20 dollar switch (looks like standard 5 pin relay), so I said I'd give it a go myself. But it' s not as straight forward as it sounds. Even existing threads in this forum that I looked at don't actually give me enough info. I guess the idea is to get power from ignition switch to bypass the light switch on the steering column handle and then tie it into the zenon low beams, so they come on when ignition is on and can't be turned off..
Anyone have step by step guide on how to accomplish this, or am I in way over my head?
Thanks,
Theo
Old Aug 13, 2024 | 11:53 PM
CorStevens's Avatar
The car already has the capability. Use IDS to turn them on. There are three settings available.
Old Aug 14, 2024 | 12:09 AM
Theo14's Avatar
Thanks Cor, that's great. Could you expand a bit though? What's IDS? Forgive my ignorance, but the car did not come with any manuals and I'm still working on getting my post count up, so I can download them.
Cheers,
Theo
Old Aug 14, 2024 | 01:15 AM
CorStevens's Avatar
Cheers,
Theo
It is software access through the OBDII port. Simply lookup JLR (Jaguar, Land Rover) IDS on eBay. It is a VM software with a special OBDII cable which you can run on a Windows 10 PC.
I recommend these folks:
https://www.ebay.com/itm/225748860049
Best.
Old Aug 14, 2024 | 05:17 PM
Theo14's Avatar
Thanks Cor, Sounds like a sound investment.
Cheers,
Theo
Old Aug 14, 2024 | 09:22 PM
Theo14's Avatar
Alternatively, great youtube video on DRL subject and other lighting mods
cooldood
Jun 2, 2021 03:16 AM
platinummaker
Dec 30, 2017 12:20 PM
S-Type
May 23, 2017 03:51 PM
BWoodbury
Mar 10, 2011 07:51 PM
