Dead radio xk8 2002
Old Jun 29, 2020 | 03:01 PM
AltoPaul's Avatar
Smile Dead radio xk8 2002
Went dead, check radio fuse and power amp fuse in boot. Does anyone know is there are in line fuses in this system? Or does anyone know of a wire diagram for sound system? Thanks. Paul
Old Jun 29, 2020 | 09:29 PM
Johnken's Avatar
Connection 44, 45, 46, are battery from trunk fuse box
Paul, these came from year 2003. I almost asked you if you have premium of standard, then realized you mentioned amplifier <=> premium (duh John).
By dead, do you mean no lights,nothing? If so focus on radio. You can easily reach its connections in the rear. The carpet is just hand stuffed into the area behind the radio & console. Just yank it out. You may even get the power connection out far enough for your DMM.
John
Old Jun 30, 2020 | 02:45 AM
Originally Posted by AltoPaul
Went dead, check radio fuse and power amp fuse in boot. Does anyone know is there are in line fuses in this system? .....
There's a 5 amp fuse for the head unit. No 12 in the LH fascia end fuse box.
Old Jun 30, 2020 | 10:07 PM
zray's Avatar
Originally Posted by Johnken
“.....By dead, do you mean no lights,nothing? If so focus on radio. You can easily reach its connections.......”
if the radio lights do come on, but no sound, could be the amp is toast. Mine was.
Z
TreelandXK8
Mar 18, 2019 04:46 PM
Camerenxj6
Jul 14, 2018 01:48 PM
tmurena
Oct 9, 2017 12:11 AM
Capper
Jul 7, 2016 07:57 PM
JessN16
Jan 28, 2013 04:44 PM
