DIY chain tensioner replacement
Old Feb 9, 2011 | 01:18 PM
Dalen's Avatar
Default DIY chain tensioner replacement
My 02 XK8 has 67,000 miles on it and I am thinking it would be a good time to finally change out the plastic tensioners. While I am somewhat mechanical and believe I could do this myself I figured I would ask if there is anyone in the Southern CA area (Los Angeles, Ventura, or Santa Barbara county) who has done this with success and would be willing to help me out. I would be willing to compensate anyone willing to help. I called a local shop and they wanted $$$ to do the job. Anyway, I thought I would put it out there for anyone willing to help.
Old Feb 12, 2011 | 11:54 PM
tireworlddave's Avatar
If you are going to attempt this yourself, I'd strongly recommend getting a subscription to AllData. It will prove invaluable.
Old Feb 16, 2011 | 05:16 PM
eaglexkr's Avatar
Smile DIY Chani replacement
Many of us with your experience have done the job.Do a search on the forum for all the threads and post.Read and review what is required,get the right tools and you will be fine.
If you get into trouble, jump onto the forum and someone will try to help.
Good luck!
Old Feb 16, 2011 | 06:23 PM
Spurlee's Avatar
Somewhere along the way Jaguar upgraded the tensioners, make sure you need to change them.
Do it yourself or pay someone, just get it done. Mine let loose at 65,000 and it cost me $4K to replace upper tensioners, lower tensioners, guides and chains, T-stat, gaskets, flush and new fluids. I was lucky in a manner of speaking since when it skipped a tooth it didn't bend a valve or worse. The chains were fairly well stretched, I don't know if an upper tensioner change would do much for that...
If you do chains and lowers I believe you'll need a particular tool to reset the timing.
Good luck!
Forcedair1
Sep 8, 2025 01:57 PM
Jpav27
Jul 31, 2022 06:43 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Bowman
Sep 15, 2015 06:54 AM
KarimPA
Sep 3, 2015 07:32 PM
