Door Hinges
Old Oct 27, 2010 | 06:47 PM
Reverend Sam's Avatar
Go to the Girls on Cars thread in the off topic section and post some pictures of girls on cars.
Old Oct 27, 2010 | 06:52 PM
Gus's Avatar
Gus
Keep on posting!
Old Oct 27, 2010 | 07:57 PM
Copesetic's Avatar
Originally Posted by Gus
Keep on posting!
I know I was just kidding, post count +1, cha ching!
Old Oct 27, 2010 | 08:16 PM
Gus's Avatar
Gus
Well another two to go!
Old Oct 27, 2010 | 09:42 PM
Copesetic's Avatar
I don't know any girls that I like enough to sit on my car, if you want to donate your car for that I will see what I can drum up.
Old Oct 27, 2010 | 09:49 PM
Copesetic's Avatar
And finally number 10, I'd like to thank everyone for all of your support in getting me to this point in my forum career!!!
Now bring on that door diagram.
Old Oct 29, 2010 | 07:47 AM
Copesetic's Avatar
The door has 2 hinges and one check arm I call a damper or stay but regardless of what it is called the stay often emits a clocking noise when it is not lubricated. I use white lithium grease on the top, middle and bottom. Not a lot just only what is necessary. WD40 is great for short term lubricating and cleaning.
Hey Gus,
When are you going to open up my account so I can see this diagram?
Cope
Old Oct 29, 2010 | 08:37 AM
  #28
Gus's Avatar
Gus
Let me see what I can do!
Old Oct 29, 2010 | 10:03 AM
Copesetic's Avatar
Got it!
Thanks Gus, your a Rockstar!!
Old Nov 3, 2010 | 05:05 PM
  #30
Copesetic's Avatar
Well I attempted to tighten that #6 bolt and it wouldn't even budge so I guess that isn't the same problem everyone else was having. Anyone else have any suggestions?
Old Nov 3, 2010 | 05:53 PM
  #31
Gus's Avatar
Gus
If the lubrication does not fix it then check the door hinges and see if they are tight. I have seen on a few older cars when neglected (never lubricated) can develop flat spots on the door pin. Let me ask if your window drops when you open the door and return when you close the door?
Old Nov 3, 2010 | 06:21 PM
  #32
Copesetic's Avatar
Yes the windows does open and close when I use the door.
Old Nov 3, 2010 | 07:32 PM
  #33
Gus's Avatar
Gus
Good then it is not the window causing it.
Old Nov 3, 2010 | 07:38 PM
  #34
H20boy's Avatar
may be time to see your dealer, drop by to say hi, tell the service guy you just bought this car, and were trying to find the best place for maintenance in the future. While in discussion about how you like your car, mention 'that damn door creaking noise' and see if he volunteers to take a look. That'll be a freebie, guaranteed.
Old Nov 23, 2010 | 07:17 PM
  #35
LedZepplin's Avatar
OK have the same problem on a 2001 XKR 50K miles drivers side door, pops when closing at 3/4 and 1/4 closed. It was the #6 bolt 10mm small socket just tighten it up and greased all the hinges just to be safe. Noise fixed. You have to love this forum
Old Jan 15, 2011 | 06:39 PM
  #36
Rwburch's Avatar
This exchange of information saved me a trip to the mechanic!
Thanx
bob
Old Jan 15, 2011 | 07:05 PM
  #37
Gus's Avatar
Gus
Good to know!
Old Jan 16, 2011 | 10:34 AM
  #38
Jag13cat's Avatar
Thumbs up Door Hinge Repair
As a Junior member myself, I posed the question some time ago about the hinges, along with a few other questions, and rec'd a number of responses. You'll find the forum to be very informative and obviously a "money saver" as you stated.
Old Jan 11, 2012 | 11:46 AM
  #39
Frog's Avatar
Apologies for bumping this ancient thread, but I've tried all the suggested remedies above, tightening all the bolts I can find on the stay, but to no avail. I even cleaned the whole area using compressed air and then regreased. If anything, the popping is louder than ever
Does anyone have any other suggestions, or am I looking at stripping the door down and possibly fitting a new stay?
Old Jan 11, 2012 | 01:52 PM
  #40
Gus's Avatar
Gus
Did you look at the hinges?
