Door insert panel replacement suggestion.
Old Nov 9, 2013 | 09:06 PM
philhef's Avatar
Default Door insert panel replacement suggestion.
I'm getting my interior just about how I want it, inspired by my XF interior, and I want to wrap the door inserts in the dark tamo woodgrain vinyl. I've covered them several times in different suede colors and fabric works fine but there's no way the vinyl will work. The panel is a thin Masonite type board with some strange molded foam.
I need a suitable surface to cover, won't flex too much, and can have a clean edge to wrap around.
Old Nov 11, 2013 | 10:22 AM
rothwell's Avatar
Maybe you could get unfinished panels from the place that sells these?
XK8 and XKR Interiors
Attached Thumbnails Door insert panel replacement suggestion.-jaguar-xk8-walnut-veneer-door-inserts.jpg
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
