dying a steering wheel
Old Jan 2, 2014 | 11:47 AM
Jag happy's Avatar
Default dying a steering wheel
Car is a XK8 convertible, 1997. Bought a replacement steering wheel for it and need to dye it. I bought the dye. What do I need to do to prep the wheel to be dyed? Clean, Scuff? Original wheel is dark grey and the replacement is black.
Old Jan 2, 2014 | 01:03 PM
RJ237's Avatar
It's difficult to sand or scuff the leather without damaging the stiching. Acetone will remove the old dye, but might attack the lacquer finish on the wood. Maybe just use some paint thinner to clean the old finish. Black should cover grey pretty easy.
Old Jan 2, 2014 | 01:16 PM
smithtrevor's Avatar
My first Jag had a worn drivers seat bolster, i ordered a matching color repair kit and the instructions said to use Methylated Spirits to "prep" the area......it did not attack the material buy cricky it did remove the dye out the seat !!!! Worth trying on a "not so obvious" place on your steering wheel....TS
Old Jan 2, 2014 | 01:23 PM
Dr. D's Avatar
I used lemon juice concentrate on a sponge. I had great results. Google it for others response.
Old Jan 6, 2014 | 01:08 PM
steven300's Avatar
if you don't want the added cost of buying the proper prep cleaner from an auto/paint store,then rubbing alcohol will do the trick.however the correct cleaner has addhesion promotors.make sure after cleaning that you let it dry so as to not have problems with the paint process.i've found a neat trick for the painting process over the years,put a dowel rod in a vise,slip wheel over it and you can spin and paint with eveness...steve.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
Burdedw
Sep 12, 2015 10:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
