Is ecm repair reliable?
Old Jul 2, 2012 | 08:25 PM
m_vrik's Avatar
Originally Posted by RJ237
My 97 also has (had) the plastic latch. Unfortunately, most of the broke when depressed so I put a dab of HT RTV on the joint after pushing them on. No problems after 2 mo. but I'm not pleased by this quality issue.
RJ_____________
97 XK8 85K mi
What is HT RTV, sorry if that's a stupid question?
Old Jul 3, 2012 | 10:37 AM
RJ237's Avatar
Sorry, High temp RTV silicone seal. The stuff you would use on the valve cover gasket at the head/front cover joint.
RJ___________
97 KX8 85 K mi
Old Jul 3, 2012 | 11:49 AM
vinoengel's Avatar
Hallo Sourlee, have a question about the comments you made on replacing an ECU upwards . Mine is AK , so i cut replace it with AL, AM,etc. That i understood. Can i use the Series Bx. As well ? I have Rough Engine Running from Time to Time with Code p1367. This fantastic Forum lead me to a ECU issue. Thanks.
Old Jul 3, 2012 | 05:39 PM
ECU Doctors's Avatar
Hi Vinoengel, we tried doing that at our ECU lab here, but it doesn't work. The programming is different.
When we installed a different ECU (LNA1410BB for example) when the car had a LJA140AK, LJA140AH, LJA140AN, the car never started.
We then we desoldered the memory and read it and found that the datas weren't compatible.
Old Dec 6, 2012 | 11:10 AM
bobinaz123's Avatar
I am a new, member with the same running rough problem. I have a 98 XK8 60K miles. I took it to a small shop that does Jags. The error code was P0205, injector problem. He also checked the plugs since they were original and changed them-no help. Then he changed the injector (5)-no help. I baught a used ECM (still with original warranty seals on it) with the exact letters and numbers from another shop. He installed and the car did not start. He then got the software from his programming system manufacturer (Autologic) and reprogrammed it. I now starts but still runs rough. Where do I go from here. Help.
Bob F 98 XK8
Old Dec 6, 2012 | 12:00 PM
WhiteXKR's Avatar
Bob F 98 XK8
I saw from another post of yours you recently had your upper tensioners replaced. If the mechanic did not prime the oil in them first by cranking the engine with the igntion or fuel injection relay disconnected, there is a very good likelihood one or both cams jumped a tooth. This would give you a very rough running engine.
Old Dec 6, 2012 | 01:09 PM
RJ237's Avatar
And it sounds like he really isn't all that sharp, ie throwing parts at it just like a dealer.
Old Dec 6, 2012 | 06:32 PM
  #28
plums's Avatar
Keep in mind that it is not a dealer specific behaviour.
It can happen anywhere. It can be prevented by good communications between an owner and a mechanic if both are sufficiently knowledgable.
Old Dec 6, 2012 | 06:47 PM
RJ237's Avatar
Yes, that was not properly worded. But too often on this forum I have seen comments about indies and dealers too quick to swap parts at the owners expense. I think it comes from being in a hurry to do warranty repairs with an eye on the clock.
Old Dec 7, 2012 | 09:14 AM
  #30
bobinaz123's Avatar
This is an extension to my last post.
The restricted performance message will sometime go away and the sequence will repeat itself.
Old Dec 7, 2012 | 09:21 AM
  #31
bobinaz123's Avatar
Sorry about my confusing message. I composed an earlier on and it just disappeared into the bit-bucket.
When first started it runs smooth. I drive it a few blocks and it starts to run rough. Also, if I accelerate to high RPM is will also start to miss. In both cases the "Restricted performance" message comes on and then it will smooth out and the message will go away.
Old Dec 7, 2012 | 09:23 AM
  #32
bobinaz123's Avatar
The tech is checking the wiring harness for damaged wires.
Any other suggestions?
Bob F
Old Dec 14, 2012 | 10:15 AM
  #33
bobinaz123's Avatar
Well, my 3 week troubleshooting ordeal is over. They found a bad solder joint in the control wire between the ECM and the number 5 injector. It failed intermittently due to vibration at idle and sometimes at higher rpms. Expensive to find--easy to repair.
Bob F
Old Dec 14, 2012 | 10:18 AM
  #34
Jon89's Avatar
Thanks for following up with your findings and fix. Here's to happy motoring for you now....
Old Dec 14, 2012 | 05:50 PM
  #35
plums's Avatar
Thumbs up
Bob F
That's a new one, so reporting back with is especially good as it will be helpful for others.
The wiring is getting any younger on these cars
Old Aug 28, 2014 | 01:35 PM
  #36
Paintxpert's Avatar
If I may chime in. I just purchased a 1997 Jag XK-8 Coupe from FLA. It seems all the harness plugs going into the coils are very brittle and broken. Prior Mechanic apparently used RTV Silicone clear to make certain they stay connected. No check engine lights yet. But would sure welcome any suggestions for a fix. Do I have to do an ECM??? What a nightmare. Fla may have no rust but their Sun is also a killer. Thank-you to all who help. Be well!
Old Aug 28, 2014 | 02:31 PM
  #37
RJ237's Avatar
This is a duplicate post to the one you made in the XK8 coil problem thread, and has little to do with the topic of this thread. Hopefully one of the overseers of the forum will eliminate it.
Old Aug 28, 2014 | 03:29 PM
  #38
brgjag's Avatar
My old 97, I had the ECM rebuilt about 5 year ago now I think. The current owner of that car lives around me and time to time I talk to him, no mention of that ECM acting up. If it had he would tell me. He always asks me about this or that on the car. Just last week he came to my house to ask where I got the tires for the car as he needed the spare tire to be the same for car show sake. I was thinking, damn dude, write down what type of tire it is and GOOGLE IT.
bdboyle
Sep 16, 2019 05:58 PM
Arlo
XK120 XK140 XK150
Nov 1, 2015 05:44 PM
Etip
Oct 1, 2015 09:01 PM
John Fox
Sep 19, 2015 07:56 PM
Doovoe
Sep 8, 2015 05:42 PM
