Electrical issue
Old Aug 29, 2017 | 04:58 PM
Bob Ford's Avatar
Default Electrical issue
Went out to start the car and the battery was dead. Got it started. Tried 2 days later, battery dead again. Also noticed the windshield wipers were off but still were running when I turn the ignition key, like they won't fully shut off. Also the window keeps creeping down after I had put them up. How is this all happening when there is no key in the ignition and is this my battery problem?
Old Aug 29, 2017 | 05:03 PM
Gus's Avatar
Gus
Have your battery and charging system checked. You can take it to Auto Zone, Advanced Auto or Sears they do it for free.
Old Aug 30, 2017 | 09:51 AM
fmertz's Avatar
Double check the little trap door switch at the ignition switch, right where the key goes. It is known to stay stuck in the open position, leading the car to "think" the key is still in, leaving circuits activated, and draining the battery. Probably needs some lubricant.
Of course, you car will need a good battery to work correctly.
As you battery drained, you will need to reset the windows. Press and hold the window up button until you hear a faint click. Hold the down button until you hear the same. Repeat on the other side. That should do it.
Old Aug 30, 2017 | 12:53 PM
RobXK8's Avatar
My windshield wiper always turns on when I start the car. But it's because I have long legs and even with the seat all the way back I end up hitting the wiper stalk with my knee when I'm settling in.
Old Aug 30, 2017 | 08:26 PM
Bob Ford's Avatar
I'll give that a try. Just spray some non flammable lubricant in the keyhole?
Old Aug 30, 2017 | 08:40 PM
fmertz's Avatar
Well, the switch is what closes the keyhole when there is no key in it. You should be able to see it (it's not deep in the keyhole). That is what needs lubrication. I assume you would want to use something you would not mind coating part of the key and find it's way on your hands and pockets. I would start with a silicone-based spray.
Best of luck, keep us posted.
Old Sep 11, 2017 | 07:23 AM
Bob Ford's Avatar
And the hits keep coming....bought new battery, now the car has an engine code light, the cars in failsafe mode with a restricted performance warning.
Old Sep 11, 2017 | 08:25 AM
JimmyL's Avatar
You might as well get yourself a code reader and put some info in your signature line. This may take a while.
Old Sep 11, 2017 | 08:58 AM
cat_as_trophy's Avatar
Hi Bob . . . and don't panic yet. Rarely are new batteries sold fully charged. Threads here are full of members reporting that their new battery actually delivers worse results than expected. Alternatively, battery cable connections, and especially ground connections to body, are notorious culprits . . . more so if disturbed, and you have been in there.
There is only one measure that is relevant here and easily done and it is not "good" or "fully charged". . . measure the actual battery voltage using a DVOM or whatever you call a multimeter. Anything less than 12.6V deserves a charge. Do not allow the "surface charge" present immediately after a charge to inflate the true value . . . wait until the morning after. Remove, inspect and clean all those major battery and ground connections.
These may not be sources of your problem . . . yours may be a Jaguar just like one I once had, which falls apart all by itself in the dark of night . . . but I don't trust mysterious coincidences until proven, and your symptoms still point to a battery voltage problem.
Best wishes,
Ken
Old Sep 11, 2017 | 08:10 PM
Bob Ford's Avatar
Any recommendations on a code reader? Took the car to have tires balanced and a front end alignment. I was told I had a leaking waterpump(they showed me) a bad ball joint and tierod. They said I'd have to have the rack replaced $1700.00 and water pump $350.00.
Old Sep 11, 2017 | 08:21 PM
Gus's Avatar
Gus
If you have a smart phone download Torque and go to ebay and get a OBDII Bluetooth adapter and you will be set. As for the water pump simple to replace.
Link to Water pump JagRepair.com - Jaguar Repair Information Resource
Tie-rod not a problem, Ball joint a little more difficult to deal with. What is wrong with your rack that it has to be replaced?
Old Sep 11, 2017 | 11:05 PM
grantorino62's Avatar
Bob, put year and type of Jaguar in your signature please.
Old Sep 12, 2017 | 03:13 AM
+1 to Gus on both rack and w/pump. Several good write-ups on both here to add to Gus' JagRepair.com link.
Cheers,
Ken
Old Sep 12, 2017 | 07:26 AM
Bob Ford's Avatar
I checked youtube(love that site) Watched a guy replace his tie rod in 20 minutes. Looks like it took a special tool to unscrew the other end of the tie rod. Where can I get that tool?
Old Sep 12, 2017 | 07:40 AM
Bob Ford's Avatar
I don't know Gus. I think they were just scamming me because I came in with a Jag, and maybe they didn't know how to fix it. Heck after 4 hrs there, They pulled off the centercaps and I was missing 6 lug nuts. They are regular 1/2 inch nuts and they charged me $95 for 6 damn lug nuts.
Old Sep 12, 2017 | 07:44 AM
Bob Ford's Avatar
Is this the OBD11 I need? OBDII Auto Scanner Code Reader Bluetooth CAN OBD2 Scan Tool for Torque Android | eBay
Old Sep 12, 2017 | 08:38 AM
fmertz's Avatar
Do a search for "ELM327", there are TONS of options. The latest models have both Bluetooth and WiFi, so should work with both Android and Apple devices.
Old Sep 12, 2017 | 03:34 PM
Bob Ford's Avatar
This the one? ELM327 Bluetooth OBD2 OBDII Car Code Reader Diagnostic Scanner For Android PC
Old Sep 13, 2017 | 08:32 AM
fmertz's Avatar
I have the Bluetooth version of this one:
W903-ELM327-OBD2-OBDII-Auto-Bluetooth-WiFi-Diagnostic-Scanner-Tool-iOS-Android
There are TONS of choices, including from vendors with stock in the US (faster shipping). Remember, Bluetooth versions are for Android devices, iPhones have to use WiFi devices. Easiest is to pick a device that does both as they are pretty cheap.
Old Sep 16, 2017 | 03:01 AM
Bob Ford's Avatar
Does the one you posted work on the V8 models? According to the "compatibility" chart it just says for V6?
