Electrical questions for the pros
Old Apr 15, 2008 | 08:28 PM
mlewisfwa's Avatar
Default Electrical questions for the pros
1997 XK8
Question 1
What are the wires going to the “Leaping Jaguar” emblem on the front fenders?
Question 2
My XK8 does not have the trunk mounted cd changer. It appears the wiring harness is in the right rear fender. Is it has simple as installing the changer, plug it in to the harness and it will work?
Thanks again to all the Jag pros for your help…….
Old Apr 15, 2008 | 08:35 PM
FactoryJaguarTech's Avatar
Default RE: Electrical questions for the pros
Q1 - Those wires are there incase you decide you want turn signal repeaters. Some markets require them by law.
Q2 - CD changer will plug in and should play fine. Just don't use too long a screw for mounting it to bracket
Old Apr 15, 2008 | 08:47 PM
mlewisfwa's Avatar
Thank you very much, this forum has saved me tons of time researching.
Old Apr 16, 2008 | 06:55 PM
jag_genius's Avatar
connector for the fenders may only be on one side..
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Shawn Svacha
Feb 6, 2022 04:53 PM
WinterJag
16
Oct 9, 2015 07:49 PM
wcourt3010
Sep 9, 2015 04:34 PM
