Evap purge valve - must I remove wheel well covers
Subscribe
Aug 3, 2011 | 10:30 AM
I'm accustomed to my xj40 and I need to change the purge
valve on my sisters 2002 xk8. Must I take the entire wheel
well cover off or just loosen the front portion?
Also I have a question about the connector to the purge
valve. It isn't a bosch type or PM type connector, do you just pull
it apart or are there ears that need to be pressed to
release them?
Reply 0
Aug 3, 2011 | 11:58 AM
IIRC, no tools required, and connections were either hose over nipples and electrical harness plug...can't recall if it had a depressed-tab or not. Its very self-explanatory when you remove the wheel well cover. The rearward part, at least...but you might as well do the front side of it also (only another 4 fasteners), it'll keep you from getting the plastic-scratches on your arm when you're working in that area.
Reply 0
Subscribe
Currently Active Users (1)
