External temperature sensor not accurate
Old Dec 28, 2017 | 06:41 AM
avern1's Avatar
The external sensor is connected to the Climate Control System. The external sensor went out on my XK. It was reading 136 F and it would get great AC but no heat without going to max high on the controls. I changed out the sensor and the system went back to responding to setting the temp/auto mode.
Old Dec 28, 2017 | 12:00 PM
Lady Penelope's Avatar
There is a DIY self test on the A/C control head as there is on my 96 X300 and may point to a fault . I believe the temp sensor is a thermistor and can be calibrated to read a specific resistance in a ice water and boiling water dunking
O C / 32 F = 5900 ohms
100 C / 212 F = 0190 ohms
The lower the temp the higher the resistance . Ruairidh , by removing the connector you mimic a lower temp which may trigger the heater to go high output . A shorted connector ( water ) mimics a high temp so the heater output goes low . Ruairidh , listen with the hood open the electric heater water pump to turn on with the key in the on position , engine not running . See page 45 and page 110 for the self test of the Doc. below :
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
There is also a temp sensor inside the cabin that gets clogged and unresponsive
Poet
Oct 6, 2015 09:40 PM
avern1
Sep 17, 2015 02:25 PM
Tipptone
Sep 16, 2015 07:39 AM
chatmanx
Sep 11, 2015 07:17 PM
tberg
Sep 7, 2015 07:32 AM
