Fascia
Old Mar 9, 2018 | 09:28 AM
jelu02's Avatar
Default Fascia
Hi,
What is that fascia (console) called which holds gauges for water temp, clock and battery charging?
I had a navigator which stopped working and now I want to replace that fascia with the one holding those 3 gauges.
Anyone knows where to get the whole assembly?
Old Mar 9, 2018 | 12:00 PM
DevonDavid's Avatar
https://www.autoreservejaguar.com/ja...oil-gauge.html
(As I'm sure you are aware, it is oil pressure (sort of !!) not water temperature.)
Old Mar 9, 2018 | 03:47 PM
astromorg's Avatar
And don't forget this bit
XK8 / XKR Navigation to 3-Gauge Conversion - TheJagWrangler
Old Mar 10, 2018 | 07:25 AM
Orthodixie's Avatar
And make sure you add a RealGauge unit so you can trust the water temp.
Old Mar 12, 2018 | 04:11 AM
jelu02's Avatar
Thank you all for your answers.
Is the wiring and fitting for these two instrument packs the same?
https://www.autoreservejaguar.com/xk8-xkr-1996-2002-minor-instrument-pack-clock-voltage-oil-gauge.html
I
will consider installing the RealGuage water temp and oil pressure, since these seems to be very inaccurate.
sidewalkman
Audio/Visual Electronics
Sep 7, 2013 10:07 AM
monz87
Nov 25, 2009 05:05 AM
Morgai1
Mar 27, 2009 06:30 AM
Peter.H
Nov 5, 2008 06:16 AM
Jun 13, 2007 08:34 PM
