Fogging up
Old Jan 23, 2017 | 02:38 PM
Rigelprime's Avatar
Default Fogging up
OK here is a situation which has arisen with my 1999 XK8. After days of rain it cooled off last night. I got in the car this morning and imagine my surprise when after clearing the ice off the windows, I found a very heavy layer of moisture on the inside too. It was not on the seats or dash or other surfaces though, just the windows. I had driven from my home to Vancouver - about three hours travel time - in heavy rain and noticed no leaks, so I am at a bit of a loss to determine where this moisture came from. Does anybody have any suggestions? Is this simply normal for a convertible? The XK8 is my first so I am not sure.
Old Jan 23, 2017 | 05:22 PM
avern1's Avatar
I experienced the same problem when I had my Jag's in ketchikan, Alaska. I found after driving if I left the window slightly opened and allowed the entire vehicle to come to the outside temperature helped. I could close up up for the night and it helped.
I also found that if I let them set for a few days closed up with warm days and cold nights I had the same moisture problem.
Old Jan 23, 2017 | 05:35 PM
Mikey's Avatar
This is one good reason to leave the HVAC system in 'auto' setting year round. The AC will automatically come on and dehumidify the car.
Old Jan 23, 2017 | 06:02 PM
Rigelprime's Avatar
thanks guys. both good advice. Oh the joys of a new car... off for a spring tune up in the morning...
Old Jan 24, 2017 | 02:10 AM
Originally Posted by Rigelprime
..... I got in the car this morning and imagine my surprise when after clearing the ice off the windows, I found a very heavy layer of moisture on the inside too. .....
I've moved your question from General Tech Help to XK8/XKR forum for advice from members with the same model.
I've found exactly the same with my 2001 XK8, 2005 XK8 and, to a lesser extent my current XK. It never happened with previous XJ6's, XJ40, X300 or X308.
My XK8's have all been Coupes so I think Coupe or Convertible is not relevant to the issue.
Old Jan 24, 2017 | 09:55 AM
rothwell's Avatar
...After days of rain...after clearing the ice off the windows...
I think your car was crying. It wants to go to Florida for the winters.
Old Jan 24, 2017 | 10:41 AM
jimbov8's Avatar
Maybe a good idea to chalk test the door seals also. Always recommend leaving the A/C on auto permanently.
Old Jan 24, 2017 | 12:24 PM
Jimmy 68's Avatar
Had this problem last night. Its been raining alot here in NJ, and I had to drive around with a rag in one hand wiping the windows so I could see with the defrost on high.
I use the ac year 'round too, but the defrost is not blowing well on the driver's side.
I also have a bad boot leak to address, too, thats not helping!
