Front Air Dam
Old May 4, 2013 | 07:43 PM
Mike Graham's Avatar
Default Front Air Dam
Hi All,
I have been driving my car a while without a front air dam. I live in Texas where it gets hot. It has been 92* F already. I used an infrared digital temp gauge to see how hot the car gets. I aimed for several places and the hottest spot I could find was 186* F. Is this reliable? The hottest place was the thermostat housing the overflow tank and directly on the radiator. They were pretty much the same. Is this reliable and how important is that front air dam?
Old May 4, 2013 | 07:53 PM
WhiteXKR's Avatar
The front air dam is probably not super critical, Unless you are running a low temp. thermostat though, when idling in the heat I would be surprised if you do not hit at least about 200 F on the internal coolant temp. sensor which you can monitor with a real time OBDII scanner or RealGauge. This wouuld be normal, and not considered a problem.
H20boy
Dec 24, 2024 03:23 PM
Mugatu
22
Jun 23, 2020 01:50 PM
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
mhamilton
US Lower Atlantic
Sep 4, 2015 05:00 PM
