Fuel pump replacement
Old Mar 12, 2021 | 11:12 AM
Gerard's Avatar
Default Fuel pump replacement
I have a 2000 XKR and need to replace the fuelpump, I have managed to remove the flange from the top of the tank (with the tank still in place) but how is the pumpheld into the tank?
Any help, photos or diagrams would be appreciated and very useful.
Old Mar 12, 2021 | 11:28 AM
Gus's Avatar
Gus
This is how I did my 99 fuel pump.
Link to fuel pump replacement. JagRepair.com - Jaguar Repair Information Resource
Gus
Old Mar 12, 2021 | 01:22 PM
Higgins's Avatar
Note that there are two fuel pumps on the Xkr 4.0
Old Mar 12, 2021 | 03:28 PM
motorcarman's Avatar
I leave the battery and spare wheel but I have a large piece of plywood and some 2x4 lumber to slide the tank out onto.
If you damage the 2 fuel lines under the tank, please note that they are NLA.
You WILL have to find good-used replacement lines.
Many have suggested that dragging the tank part-way out with the lines still connected is OK. (IT IS NOT)
You may or mat not get away with it?
Old Mar 13, 2021 | 01:24 AM
tsuppari's Avatar
I replaced MY1999XKR Coupe pumps through subwoofer hole without removing tank (there is threads about it somewhere here). They are held by 8 or 10mm bolts inside tank. Should be quite easy todo. Small hands will help
roman_mg
Aug 10, 2020 10:06 AM
Bc xj
Jun 21, 2014 05:37 AM
mike66
Mar 1, 2014 10:21 AM
Sledgehorn
Oct 26, 2012 01:42 AM
Kevin93940
Feb 24, 2011 08:23 PM
