Fuel pump woes
Old May 29, 2020 | 09:41 AM
MCW739's Avatar
Originally Posted by PJMoore
2001 XK8 Conv. In storage. No start. No fuel rail pressure. Swapped fuse #7 (20amp) - no help. Swapped fuel pump relay. No help.
Time to dig out the wiring diagrams. On this car, The ignition switch closes on start/run to ground. This completes the circuit from the battery, through the Ignition Positive Relay coil, a diode, and the closed inertia switch.
The N.O. Ignition Positive Relay contacts then close, feeding battery power to fuse #3 (5amp), then to the Fuel Pump Relay coil, then on to the ECM output. The ECM output grounds the circuit ( to complete this circuit) in start/run.
The now energized Fuel Pump Relay closes its N.O. contact, connecting the battery to fuse #7 (20amp), then on to the fuel pump to run it.
So I guess I need to also check the Ignition Positive relay, as well as fuse #3 (5amp). I sure hope it isn't the ECM. Based on the fact that it has been in storage for several months, I'm betting it's the fuel pump has decided we have abandoned her, and has lost its will to live. My bad.
Film at eight.
If you remove the pump relay you can 1.check the supplies to the relay and 2.by placing a link across the no contacts you can see if the pump runs, you will hear it.
Old May 29, 2020 | 09:48 AM
xkr_dougie's Avatar
Very clear and also my suggested way forward!
Old May 29, 2020 | 05:35 PM
mhminnich's Avatar
Would a faulty fuel pressure transmitter on the fuel rail spoof the ECM into thinking the rail was already pressurized and thus prevent the pump from running?
WhiteXKR
May 12, 2026 01:19 PM
leo_denmark
Apr 19, 2018 01:42 AM
bandre2
Dec 13, 2015 03:41 PM
Mike Trusky
Oct 21, 2011 08:46 AM
dlpoling
Apr 20, 2011 08:41 PM
