Fuel rail
Old Apr 12, 2025 | 05:01 PM
warren8959's Avatar
Default Fuel rail
This picture is of a 1999 XK8 non-TC fuel rail. As we can see in this photo, a rubber hose connects the left side of the fuel rail to the right side. Has anyone ever tried to splice into this rubber hose to install a T-fitting for a fuel pressure gauge? If a 1/8" NPT T-fitting can be spliced in, it would be much easier than trying to rig up a combination of AN fittings, a Schrader valve fitting, and various NPT adapters to the Schrader valve on the fuel rail, to just end up with a Rube Goldberg way of attaching the fuel pressure gauge to the fuel rail.
Has anyone ever replaced this rubber hose?
Old Apr 13, 2025 | 01:26 AM
Pistnbroke's Avatar
And why would a fuel pressure gauge be any use to you?
Old Apr 13, 2025 | 09:12 AM
warren8959's Avatar
So you're driving along, and the car just dies, and your first thought is WTF. If it's a fuel-feed problem, the fuel pressure gauge will tell you. I do all my work on my cars, so that's why.
Old Apr 13, 2025 | 09:30 AM
clubairth1's Avatar
Community Influencer
I don't know?
When I do this type of work my fuel pressure gauge plugs right into the Schrader fitting? No adapters needed?
Mine has a longer rubber hose and I run that out the backside of the hood and tape the gauge to the windshield so I can read it.
It might be easier to use Torque Pro or some other type of scanner and just read the fuel pressure electronically?
Have you tried that?
Old Apr 13, 2025 | 09:42 AM
Pistnbroke's Avatar
or you could get out and blip the Schrader valve
Old Apr 13, 2025 | 01:02 PM
Y2KJag's Avatar
I don't know?
Yes, I used something similar the other day when I was checking fuel pressure.
The 4.0 cars don't have a fuel pressure sensor, so it can't be read electronically.
Old Apr 13, 2025 | 03:44 PM
xalty's Avatar
pocket screwdriver my guy
don’t make this more difficult than it has to be
BradsCat
Dec 19, 2023 04:07 PM
iconic
Jun 1, 2016 11:44 AM
JigJag
May 18, 2016 08:22 PM
tedhaywardart
Dec 2, 2012 01:16 PM
