Fuel Sender - Alternative Brand?
Old Oct 17, 2024 | 01:48 AM
XK8FAN's Avatar
Default Fuel Sender - Alternative Brand?
Anyone know of a different brand fuel sender that will work on a 2000 XK8? PN LJA2000AC
Even used Jag ones are going for crazy money and may have the same issues.
I will be testing mine with resistors and a multimeter tomorrow, but after four tanks of gas the gauge still gets stuck at just under 1/2 on the way down. (I got caught running out the first time!) I really suspect that sender...
E
Old Oct 17, 2024 | 11:56 AM
Y2KJag's Avatar
E
It's highly likely the sender has issues. The rheostat portion wears out and you get funky readings. I see new ones available online for $200 - $250. From a Jag standpoint, that's not all that expensive. Just bite the bullet. Look at it this way - it'll last another 20 years, so it's only going to cost you $12.50 a year.
Old Oct 17, 2024 | 01:09 PM
XK8FAN's Avatar
May end up there. Tested it out with resistors and a multimeter. Dash gauge works fine with resistors. MM shows 230 ohms through the sender. Tank is just below half, so that may be believable. I'll run it down a lot more and test again. I was hoping it was a sticky float that might dislodge with driving on Indiana's lovely potholed roads! It just bugs me that run of the mill senders are $40 while this car supposedly needs ones made from unicorn horn.
Old Oct 18, 2024 | 02:16 AM
dibbit's Avatar
Mine got stuck for a while, but eventually started working again. The fuel used display on the dashboard works independently of the tank float, so you can use that to avoid running empty.
It might be worth adding a can of injector cleaner to the tank and letting it sit in that for a while, or you could even remove the sender and give it a clean with contact cleaner.
Old Oct 18, 2024 | 02:18 AM
Pistnbroke's Avatar
Best I found on UK Ebay was $25.........
Old Oct 18, 2024 | 10:48 AM
XK8FAN's Avatar
Thank you. I was hoping the same (car had clearly sat for a long time - only driven 1500 miles per year for the last 20 by the PO! I've done 900 with good quality fuel and no change yet, so...
In the end I snagged a new one from the UK for GBP £48 ($92 all-in, inc. shipping). (Since found
I will assess the outcoming one (using your advice) and either keep it as a spare or sell on eBay, if I can fix it. It's crazy. The cheapest on eBay USA is a used one from a less than perfect seller for around $150 all-in. Any good looking but still untested are $180+.
Spikepaga
Nov 3, 2022 04:12 PM
logger
Mark V - X 420G
Feb 4, 2022 07:14 PM
Jerry Redmond
US Lower Atlantic
Jun 8, 2018 04:04 PM
agd
Nov 9, 2016 05:09 PM
jzz
Jun 19, 2009 07:08 PM
