Gas tank
Old Nov 17, 2014 | 02:21 PM
randyb's Avatar
Default Gas tank
Is the jag tank aluminum or stamped steel?
Old Nov 17, 2014 | 02:53 PM
smithtrevor's Avatar
Try the Magnet test!!
Old Nov 17, 2014 | 03:40 PM
brgjag's Avatar
if the magnet does not stick to it then it has Bondo in it.
Old Nov 17, 2014 | 04:11 PM
DaveInVA's Avatar
Or plastic roofing tar like I found covering a gas leak on a car I once had...
Dave
Old Nov 18, 2014 | 06:32 AM
jamdmyers's Avatar
From JTIS
The steel fuel tank is located inside the trunk and mounted across the vehicle behind the passenger compartment bulkhead.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
bdboyle
Sep 16, 2019 05:58 PM
hkmcmast
Nov 29, 2015 06:56 AM
vwbusbits
Oct 13, 2015 03:43 AM
