? gas tank float repair before new rear sway bar and frame brace
Old Jan 5, 2014 | 09:28 AM
weisberg's Avatar
Default ? gas tank float repair before new rear sway bar and frame brace
I am planning to have the UltraRacing rear anti-roll bar (20 mm) and frame brace done to my 2002 XKR coupe but wonder if the $450 repair for my gas tank float should be done at the same time or before?
Anything else that should be done at the time those parts in the rear get done?
Old Jan 5, 2014 | 02:37 PM
ccfulton's Avatar
The fuel tank is in the boot, so there isn't any real relationship to the rear suspension. Up to you whether you want it fixed now or later.
You might also replace the panhard bushings with powerflex ones, but if you expect to some day install a LSD, that would really be the time. The easiest way for the LSD is to drop the cradle which makes all the bushings and shock mounts and everything else very easy to get at.
99xk8guy
Sep 29, 2025 10:51 PM
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 12, 2015 08:15 AM
alpecsa
Sep 7, 2015 11:55 AM
KarimPA
Sep 3, 2015 07:32 PM
