Ground clearance
Old Nov 30, 2017 | 07:46 AM
ronrowand's Avatar
Default Ground clearance
Just got XK8 2005. Ground clearance at front 6". Scraping on driveway grade change. Is this standard clearance. Any easy way to add an inch or two?
Old Nov 30, 2017 | 08:13 AM
Johnken's Avatar
Check your ride height. Measured from edge of fender to center of wheel. Search for specs, they are posted on this site.
Clearance will be tied to ride height. Too low, check spring and or shock mounts. You could easily be low by an inch or more with collapsed upper shock mounts.
John
Old Nov 30, 2017 | 08:22 AM
mrsclark's Avatar
You could see if you could increase you wheel/tire size. If you have room to do so. It may look good filling up the wheel well space.
Old Nov 30, 2017 | 04:51 PM
ronrowand's Avatar
John
Thanks, Johnken;
Need help finding ride height specification.
Old Nov 30, 2017 | 05:40 PM
clyons's Avatar
