Halfshaft Ujoints
Old Mar 15, 2010 | 05:34 PM
Fraser Mitchell's Avatar
I still have my "Wanner" grease gun in my tool chest !!
I used to use an HP Molyslip grease. This was OK for virtually all of the grease nipples on the Jaguar, and Oh, how many there were !!
As I recall:-
Front suspension top and bottom ball joints (sealed from XJ40 and they lasted longer !)
Wheel bearings
rear hub carrier trunnion bearings
inner and outer UJs
inner swing arm bearings
prop shaft UJs
Have I missed anything ?
Old Mar 16, 2010 | 08:03 AM
chazaroo's Avatar
Stopped at Jaguar for an oil change yesterday and asked the service advisor if greasing the U-joints was part of the service and he said no. I asked if they would do it anyway and they did. The point is, they haven't been doing it. So if you take your car in for an oil change, you had better mention the U-joints.
Old Mar 18, 2010 | 09:57 AM
Gus's Avatar
Gus
How to Check U-Joints
You get the car off the ground then place your hands at 6 & 12 o’clock position and see if you have movement then try it 9 & 3 o’clock. If you have movement from the 6 & 12 position then look at placing your hand on each U joint to find the one that is in trouble. If you have movement from the 9 & 3 position you may not have a U joint problem you may have a wheel bearing that needs replacement. I hope that makes a little sense.
Old Mar 18, 2010 | 12:12 PM
oldmots's Avatar
I have had other Jags with the ujoints, I always used mobil 1 synthetic grease or similar.
Old Mar 18, 2010 | 12:18 PM
oldmots's Avatar
Originally Posted by Gus
How is the fishing in the bay?
I haven't fished in the Bay in 20 years, but then it was amazing, pulling out 7 lb bluefish one after the other until your arms were too tired to keep going!
Old Mar 18, 2010 | 04:22 PM
Gus's Avatar
Gus
I have a place on OC Md. My back door is the bay 35 – 40 ft deep and fish every chance I get.
Old Mar 25, 2010 | 01:53 PM
oldmots's Avatar
Thought I would mention, there are no lube points on the driveshaft on the 2006. There is a flex joint at the front and a sealed u-joint at the rear in front of the pinion seal. The only lube points on the car are the four half shaft u-joints.
Old Mar 26, 2010 | 06:35 AM
  #28
GreenJewel's Avatar
This is true for the 2000 XK8 too.
Old Mar 27, 2010 | 07:54 AM
Spurlee's Avatar
The rear 1/2 shaft zerk fittings are way down in the yoke on the u-joint and may/should have a plastic cap on them. They are very easy to miss - keep looking.
In true Jaguar fashion they are located 180 degrees from each other. When you have one side positioned to grease the other side is inaccessible. I do a lot of on-off the ramps to finally get to both. Using jack stands might eliminate this process...
My caps have gone missing - I've not found replacements yet. Similar caps are all over my boat's outdrive, they might be a marine item but I still can't find any...
Old Mar 27, 2010 | 07:02 PM
  #30
hlgeorge's Avatar
Go to Home Depot or Lowe's and look in the shelving area. The white end caps for the wire shelving will work.
Old Oct 2, 2010 | 02:17 PM
  #31
AlexXK8's Avatar
My four UJ fittings took 10 pumps of grease each. I could not find any other fittings.
Old Nov 6, 2010 | 10:39 PM
  #32
Christian 96 XJR's Avatar
Chevron Ultra-Duty and Mystik JT-6 High Temperature greases are officially approved by Dana/Spicer (manufacturers of the u-joints used by Jaguar).
Old Nov 7, 2010 | 01:49 AM
  #33
H20boy's Avatar
good to know, thanks for the add stich.
Old Nov 7, 2010 | 07:41 AM
  #34
cpm53's Avatar
My local dealer told me there were *NO* grease fittings to be lubed on my 2003 XKR.....
very interesting.....
Old Nov 7, 2010 | 08:58 AM
  #35
PeteO's Avatar
I would change dealers. My 2000 XK8 and my 2006 XKR both have them and I personally have greased them.
Pete Orebaugh
Vero Beach,Fl.
Old Nov 7, 2010 | 09:56 AM
  #36
Gus's Avatar
Gus
And that is the problem, the dealerships are not doing it and they go dry and fail. Get them checked and greased!
Old Nov 9, 2010 | 06:58 PM
  #37
Gordo's Avatar
Wish I had seen this thread sooner !
Old Nov 9, 2010 | 09:42 PM
  #38
T6driver's Avatar
Default On my to do list
How do you know when you have put enough grease in the bearings? How many fittings total are there on the 06 XK8? Thanks for the great info!
Old Nov 10, 2010 | 12:23 PM
  #39
daddyo007's Avatar
When I did mine I kept squeezing until I saw grease coming out. Then just wipe off the excess, or leave it and it will coat the under carriage of the car.
Old Nov 10, 2010 | 12:35 PM
  #40
AlexXK8's Avatar
Seems to me there are two on each side on the rear split axle. They are near the wheel. Once you do one side,(with the car on jack stands) you'll have to rotate the tire some with the car in "N" because if one side is reachable the other side isn't.
