Headlamp Bulb Replacement...
Old Jan 22, 2012 | 04:53 PM
plums's Avatar
Originally Posted by Beav
'Normal' electrical practices rarely are considered in automotive wiring.
That's right.
An electrician or electrical engineer will tell you surprisingly enough that a wire of "x" AWG will handle "z" amps - as long as the insulation and application are rated for the temperature and the voltage drop is tolerable in the application. The absolute limit is the fusing current rating of a particular wire.
In lighting applications, it is the voltage drop that motivates the advice to go with 14AWG or better for each headlight bulb.
jagent
Jun 5, 2022 02:18 PM
afterburner1
Dec 16, 2015 12:12 AM
goingjag
Sep 30, 2015 09:27 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
