Headlight Drain Valve install Question
Old Jan 21, 2017 | 07:46 AM
dsd's Avatar
dsd
Default Headlight Drain Valve install Question
All,
I am in the process of installing the headlight drain valve on my 2003 XKR and have a few questions.
Reading TSB 417-005 (http://www.jagrepair.com/images/TSB/XK8/417-05.pdf), I'm left wondering why the headlight must be removed. I can access the stub pipe installed. My thought is I can drill the and then vacuum-- am I missing a reason not to do this?
Also, what function does the T-Valve actually perform. It does not appear to connect to an actual hose line. Is it there simplly for airflow and to prevent debris from entering the lamp area?
Any insight would be appreciated as I am just waiting on the valves to arrive.
As always, thanks!
dsd
Old Jan 21, 2017 | 08:26 AM
chillyphilly's Avatar
Disclaimer: I have not performed this procedure.
From what I understand, the main reason to pull the headlamp is to keep debris from getting inside. That and actual hole placement. But if you can get the hole placed and angled right without removing the lamp, along with removing any debris with a vacuum, I don't see why you couldn't do it your way. Do you actually thing you can get the shavings out of the lamp with a vacuum though? I think even if you drill and vacuum simultaneously, you will still inevitably get some small shavings inside the lamp.
That is the idea of the vent pipe, to let it breathe and block anything from reentering.
Old Jan 21, 2017 | 02:43 PM
dsd's Avatar
dsd
Well, I drilled the holes :-)
I used a dewalt right angle tool with a 11/32 drill bit (couldn't find 9mm with a hex shaft) so 8.7mm will be close enough. I would say watch your angle on the drill, I did scratch the bottom on one side as I was at a slight angle (no big deal) but the other side was perfect.
A cotton swab got most of the gunk out. I could not get a vacuum to work (too tight an area) but a bbq skewer with scotch tape (double-sided or applied sticky outward) got the few pesky plastic bits out very easily.
Now just waiting on the valves, and I can tape the hole until then or just let to be.
Old Jan 22, 2017 | 01:54 PM
rothwell's Avatar
I see that my 2004 is within the vin range but I have never had an issue with moisture. I checked and my car does not have this fix. The TSB says
"Some 1997-*2004* MY XK vehicles may experience a build up of condensation in the headlamp assembly"
I have to wonder if this fix is intended to resolve the symptom instead of the cause. Is the condensation due to poor quality of the assembly?
Old Jan 26, 2017 | 05:55 PM
Cabel's Avatar
Where do you source the vents?
Old Jan 26, 2017 | 06:39 PM
dsd's Avatar
dsd
I bought mine from Terry's Jag Parts. They were under $4 each.
Of course, I had to order a third as I dropped one into the abyss never to be seen again.
