Heater core flush - which pipe is in vs out
Old Nov 14, 2021 | 12:49 PM
Silver2002XKR's Avatar
Default Heater core flush - which pipe is in vs out
Going to do a heater core flush due to very very low heat output at any RPM... which pipe to the heater core is the inlet, and which is the outlet? I know to flush from outlet to inlet, but I can't tell which is which. :-)
Old Nov 14, 2021 | 04:54 PM
michaelh's Avatar
See the attached pdf. It is taken from the 2nd edition (1999) workshop manual, but it is the same.
Check out also this post from fmertz:
https://www.jaguarforums.com/forum/x...2/#post2118558
File Type: pdf
Old Nov 16, 2021 | 12:22 AM
Once I got the little black plastic coolant fill tank and its bracket out of the way it was a lot easier to see what was going on, and the pipe on the right was clearly connected to the heater pump (so that was the heater core inlet, and the one on the left was the heater core outlet.) I flushed it backwards, forwards, backwards, forwards, then backwards, at which point it was allowing a healthy stream of water through. Put it all back together and now I have heat, just in time for top-down-heater-on driving season in Arizona! :-)
Old Nov 16, 2021 | 06:07 AM
Jon89's Avatar
Well done....
Lawrence Watkins
Dec 10, 2022 08:52 AM
Corndonkey
22
Dec 11, 2020 03:42 PM
Lawrence Watkins
Aug 5, 2019 07:26 AM
Wingrider
Jan 9, 2018 01:10 PM
TrevorA
Mar 5, 2014 02:28 AM
