Hello and abs help please
Old Jan 16, 2012 | 03:17 PM
itspec60's Avatar
Rachel....Have you checked the brake pedal switch? I was looking at the flow chart for troubleshooting the ABS and I haven't seen it mentioned yet in your thread.
Old Jan 16, 2012 | 03:50 PM
Dennis07's Avatar
Originally Posted by trautobro
Is there a way to trick the computer into thinking the ABS and Traction control are running normally until such time that you can get it sorted.
I feel pretty certain there is not, nor does it seem we would want to except to quench the warning light(s).
Anyway, what we've got in this situation is plain old driver-controlled braking and throttle. Low-tech, yes, but works just fine if not abused.
Old Jan 17, 2012 | 07:23 PM
nine7xk8's Avatar
my fellow people, we drive JAGUARS!!! these are not toyotas. lets be real, why would a simple wheel sensor problem or module problem be that hard to diagnose. these are well put together vehicles. the zf5hp-24 german built transmissions have a weakness in them and it must be fixed. my best regards. nine7
Old Jan 17, 2012 | 07:24 PM
nine7xk8's Avatar
p.s. dont forget about the plastic tensioners
Old Jan 17, 2012 | 07:27 PM
WhiteXKR's Avatar
I agree, there is a chance that the transmission could cause the ABS fault (but so could many, many other things). It seems highly unlikely though that a mechanical failure in the transmission would cause a CAN bus fault.
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
