HELP - Module 11 test ID 0A fails high (FFFF)
Guest
Posts: n/a
I have been chasing EVAP system problems for nearly 2 years now. Dealer replaced gas cap & purge valve about 2 years ago. I have replaced CCV & CCV vent hose. Recently opened up wheel well & found that when dealer replaced purge valve new style with new vent connection was used, BUT dealer connected vacuum control line to new vent connection and left control connection open, so purge valve could not operate. I moved the vacuum control line and added a vent line & filter & my gross leak (P0455) is now solved and the module 11 test ID 07 (gross leak) now passes.
HOWEVER, the module 11 test ID 0A still FAILS HIGH with a value FFFF(OBD range MIN is N/A, MAX is 828F). I can find reference to test IDs 02, 04, 06, 07 and 08 but no reference to test ID 0A, so I have no clue what the area of the problem is.
Does anyone know what test ID 0A is? I have not yet purchased Autoenginuity but possibly someone with Autoenginuity mat be able to find reference to this test.
Thanks!
n2audio
19
Jan 20, 2025 09:35 PM
